1992 Chevy Astro 92 Astro Van ignition system
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUE69
I have a 92 Astro van with a 4.3 non Vortec that runs fine when the engine is cold but when the engine is warm it will idle fine and when you push the gas pedel to the floor quickly it will rev up ok. My problem is when I press the gas pedel slowly the engine will stall. I pulled the coil wire off the dist cap and my spark is yellow. Any advice will be greatly appreciated.
Jan 16, 2008 at 3:00 AM
MASTERTECHTIM
  • 4,750 POSTS
SOUNDS TO ME LIKE YOUR EGR VALVE IS COMING IN TOO FAST. UNPLUG YOUR EGR VALVE VACUUM LINE AND YOUR PROBLEM SHOULD GO AWAY. PLEASE LET US KNOW HOW YOU MAKE OUT..
Jan 16, 2008 at 3:05 AM
