P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
Typically this means the catalytic converter needs to be replaced. To verify this, your mechanic will watch the actions of the rear oxygen sensor. If it closely matches those of the front oxygen sensor, that means no change is taking place in the composition of the exhaust gas as it goes through the converter.
Apr 5, 2017 at 12:51 PM
