Check Engine Light and failed emissions test
150,000 MILES • 2.5L • 6 CYL • FWD • AUTOMATIC
ETEITGE
My van has been trouble. I had it repaired twice over the summer. New MAF sensor, some new O2 sensors, a new carburator... lots of expensive work. My check engine light is still on. (As an aside I will never return to the mechanic I used this summer.) I decided to try and do some work myself. I cleaned the throttle body and that seemed to help. From what I could tell all hoses seemed fine too. Do you have any suggestions? I am a rookie at best here.
Nov 3, 2015 at 3:02 PM
WRENCHTECH
  • 20,760 POSTS
I don't know what you really replaced but that car doesn't have a carburetor.
What is the code number being stored in the computer from the check engine light?
Nov 3, 2015 at 6:17 PM
ETEITGE
My mistake, I meant catalytic converter. The codes that come up are: P0102, P0171, and P0174.
Nov 3, 2015 at 10:43 PM
WRENCHTECH
  • 20,760 POSTS
See if the intake snorkel has any cracks or leaks of any kind. Maybe a hose left off.
Nov 3, 2015 at 10:56 PM
