Check engine light, I have turned it into a straight pipe?
275,191 MILES • 5.7L • V8 • 4WD • AUTOMATIC
BRITTALGER91
So, my check engine light came on and it turned out to be my catalytic converter and I have turned it into a straight pipe, now that the problem is fixed, but I still have a check engine light on. How I get that off now one it's still reading converter?
Dec 4, 2023 at 10:51 PM
  • 55,721 POSTS
What codes it is? You should be able to just clear the codes and be okay. Disconnect the battery for 5 minutes and it should be clear. Here is how to get the codes in case you don't know which code it is:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Please go over this guide and get back to us.
Dec 5, 2023 at 1:42 AM
