Check engine light?
85,500 MILES • 6 CYL
KATHERINE HOWARD HARRELL
My front fender passenger side tire blew out, it did some damage underneath where the fog light and wiring. I had it fixed, but as soon as I got my car back the check engine light came on and the key fob that starts up your car would not work. I never had a problem like that before, even before I got it fixed. Can you tell me what is wrong? I had one cylinder, four cylinder and five-cylinder misfires come back on the diagnostic would that put the check engine light on my dash.
Oct 12, 2022 at 12:41 AM
  • 55,709 POSTS
Yes, it will any engine trouble will cause the check engine light to come on. I would do a CAN scan which is easy you can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
and
Amazon CAN scanner link for about $35.00:
https://amzn.to/3R9lJ60
Here is a guide on a regular engine scan:
Let me know what codes come up so I can help you fix your car.
Oct 12, 2022 at 7:35 AM
