Check engine light on
144,000 MILES • 4 CYL • 2WD
LETITIA SMITH
Check engine light came on while driving, but it runs and sounds good.
Mar 23, 2020 at 9:54 AM
There are many reasons a check engine light can come on so the only real option is to check what codes are in the modules. If you do not have a scan tool, then most parts stores can pull codes free of charge. Clearly a repair shop can do this as well but they will most likely charge for that.
https://youtu.be/p6AduLnO-Ds
Let us know what the codes are and we can go from there. Thanks
Mar 23, 2020 at 9:58 AM
