Check engine code p0430
103,100 MILES • 2.7L • 6 CYL • AUTOMATIC
SD1414
I have a code of p0430 catalyst converter. My car has a loss of power and recently started making a knocking sound i think from inside the engine. When i step on the gas it gets a bit louder. Also, when i let go of my brake my car kind of bounces or jumps i guess you could say. I took it in and the mechanic said it was my camshaft sensor and my crankshaft sensor. So i replaced them and my car still does the same thing. Can you please give me a few suggestions of what might be going on? Thank you
Aug 31, 2017 at 4:18 PM
  • 55,604 POSTS
It sounds like your catalytic converter is failing apart inside which will make the engine run poorly and make noise while giving you the code. Here is a code that will help you confirm the problem.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Please let us know what happens so it will help others.
Cheers, Ken
Sep 4, 2017 at 5:24 AM
