Check engine light on giving code TCM
170,588 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
LSCOTT513
When driving and come to a stop, the car moves slow and then pick up speed later.
Mar 30, 2022 at 7:50 AM
Can we start with what code you are getting?
There are a couple things that we need to check and that starts with what code is there so here is a guide that will help.
Also, this may sound strange, but we also need to check the engine oil level. This engine is known for using oil and that can cause different issues but mostly stalling. So, if your engine is not stalling then it may be fine, but we need to check it and go from there.
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Let me know what codes are there and we can figure out the next steps.
Thanks
Mar 31, 2022 at 10:09 AM
