Check auto gear box?
70,000 MILES • 1.2L • 4 CYL • AUTOMATIC
ERVIN CUPI
The car has been making rattling noises for 6 years, but when I put it in manual mode, it didn't make any noise and run very smooth the problem is when i drive in automatic mode slowly stop and go car pop up message check auto gearbox and the car does not go in reverse. i switched of the car and back on and is normal again. i put it in computer to check speed sensor one speed sensor 2, but the next week the message popped up again. i put it in the computer and it said clutch 1 shot circuit to earth.
i try and drive manual mode in any gear and it is fine without rattle noise in any gear higher or lower. My car is 6 speed gar box dry clutch. what do you think?
Sep 21, 2023 at 5:06 PM
BORIS K
  • 836 POSTS
Please share the fault codes with us not just the fault description.
We can then check for possible solutions and advise accordingly.
Cheers, Boris
Sep 22, 2023 at 2:12 AM
