How to set the language default on the radio permanently?
2023 CHEVROLET TAHOE
2,000 MILES • V8 • 4WD • AUTOMATIC
ISIDORAMIRANDA99
Hello, I change the language from the radio to Spanish, but every time I turn the car back on returns the default language English. So, how can I change it permanently without being changed every time I get in my car? Thank you.
Aug 22, 2023 at 6:24 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
The process for setting the default language on the radio of a 2023 Chevrolet Tahoe may vary depending on the specific model and radio system installed in your vehicle. However, in general, here are the steps you can follow to set the language default on the radio:
Turn on the Ignition: Start by turning on the ignition of your Chevrolet Tahoe without starting the engine. Make sure the vehicle is in a safe and stationary position.
Access the Radio Menu: Use the radio controls or touchscreen to navigate to the radio menu. Look for an icon or button labeled "Menu," "Settings," "Options," or something similar on the radio interface.
Language Settings: Within the radio menu, you should find a section related to language settings. This is where you can change and set the default language for the radio display and prompts.
Select Language: Navigate through the language options until you find the desired language. Use the radio controls or touchscreen to select the language you want to set as the default.
Confirm and Save: Once you've selected the language, there may be an option to confirm and save your selection. This step ensures that the chosen language becomes the default setting for the radio.
Restart the Vehicle: Some vehicles may require you to turn off the ignition and then restart the vehicle for the language changes to take effect.
Aug 22, 2023 at 1:32 PM
