cdplayer is tune on and off
2000 GMC YUKON
149,000 MILES • 5.0L • V8 • 4WD • AUTOMATIC
HOTRODKING2001
I need help with my truck my cd player is tune on and off wend I'm driving down the road I will be listing to it and it will tune on and off fast and I can put the door luck bunting and the cd player will tune on can you help me plases. it a 2000 gmc Yukon
Nov 16, 2014 at 2:44 AM
HMAC300
  • 48,601 POSTS
have radio repair do that
Nov 16, 2014 at 3:19 AM
HOTRODKING2001
are you should the cd player need to be change wood that make the door locks mase up wend the cd player tune off and on
Nov 16, 2014 at 11:58 PM
HMAC300
  • 48,601 POSTS
your question seemed to be more about eh cd than the door locks. check battery to body ground and battery to engine ground. Also check the ground at upper left kick panel make sure no corrosion and or loose
Nov 17, 2014 at 12:15 AM
