How do i program a new key to BCM or ECU?
2011 BUICK REGAL
140,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RSHEP420
changed the entire ignition system out that slides down over the column. cylinder switch all of it came with two fobs car doesn't recognize key, so won't start won't turn over, the key will not come out. can't get it out of lock without removing battery cable. how do i program a new key to BCM or ECU? please I'm in desperate need of this answer please!
Jul 24, 2023 at 7:47 PM
  • CERTIFIED EXPERT
  • 53,872 POSTS
I understand that you are facing issues with programming a new key to the BCM (Body Control Module) or ECU (Engine Control Unit) of your 2011 Buick Regal after changing the entire ignition system. I'm sorry to hear about the difficulties you're experiencing. While I can provide some general information, it's essential to note that programming procedures can vary depending on the specific model and year of your car, and I don't have access to real-time information beyond September 2021.
In this situation, I would highly recommend reaching out to a certified Buick dealership or an automotive locksmith with experience in programming keys for your specific vehicle model. They will have the necessary tools, software, and expertise to properly program the new key and ensure it works correctly with your car's BCM and ECU.
Before visiting the dealership or locksmith, you can try a few general troubleshooting steps:
Ensure the new key's battery is functional. Sometimes, issues can arise from a dead or weak battery in the key fob.
Double-check that you have the correct key and fob for your vehicle model. Mismatched or incorrect components may not be recognized by the car's system.
Check your owner's manual or contact the seller of the ignition system to see if they provide specific programming instructions for the key fobs.
Attempt the key programming process using the car's manual or standard procedures (if you have access to them).
However, it's important to exercise caution when attempting any key programming yourself, as incorrect programming attempts can potentially cause issues with your car's security system. In some cases, programming a new key might require specialized equipment and technical knowledge.
Jul 25, 2023 at 7:17 PM
