Catalytic converter
120,000 MILES • 6 CYL
ZEIK1154
  • 26 POSTS
How can I tell if the catalytic converter is going bad or is bad? What are signs?
May 18, 2018 at 1:23 AM
Good afternoon.
You will need to do a test called back pressure test. This test is when you remove the O2 sensor up by the engine and insert a gauge that you can rent at a parts store. Then you start the engine and look at the reading on the gauge. If it is more than two inches of pressure, the converter is plugged up.
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
May 18, 2018 at 2:15 AM
