That is a lot longer than the long crank time I referred to. The long crank time means around five to ten seconds of cranking.
I would connect a fuel pressure gauge so you will know exactly what is happening related to pressure. Next would be to connect a scanner so you can see what the engine computer is reacting to. Of particular interest would be the intake air temperature sensor. It is extremely rare for a temperature sensor to fail because there is just one resistor in them, but wiring problems are common.
Temperature sensors are fed with 5.0 volts, then the sensor draws that down to between approximately 0.5 to 4.5 volts. Anything outside that range will set a diagnostic fault code. If some corrosion builds up between the two terminals in the connector, that will also cause the voltage to drop, and that incorrectly tells the computer the air temperature is higher than it really is. At higher temperatures, the computer commands less fuel for the priming squirt, and that may be too little to get the engine started.
Squirting in a little starting fluid will get the engine started if that air temperature sensor is the suspect, but to do that, you have to disconnect the fresh air tube. Every manufacturer except Chrysler needs a mass air flow sensor to measure the weight of the incoming air, then the computer calculates the correct amount of fuel to go with it. There cannot be any leaks in that tube between the mass air flow sensor and the throttle body. If any air sneaks in that does not go through the sensor, no fuel will be commanded to go with it. If you spray in a little starting fluid, you will need to reconnect the tube before cranking the engine.
Given the really long time it takes before your engine will start, another good suspect is the crankshaft position sensor or the camshaft position sensor. These often fail by becoming heat-sensitive, then they work again after cooling down for about an hour. The problem you described is more likely to be caused by an air gap that is too big, but that applies to those sensors that are adjustable. Yours are not. Still, if you have access to a scanner to view live data, it will show if signals are being received from both sensors during cranking. If either signal is missing, you will not have spark or injector pulses. When the engine finally does start, there will be no sign of excessive fuel at the tail pipe. Consider checking for spark when the engine will not start.
Nov 18, 2017 at 7:23 PM
