car will not start or crank 1999 lincoln continental
1999 LINCOLN CONTINENTAL
186,000 MILES
STCHRIS96@AOL.COM
  • 28 POSTS
Car start when cold but after driving for more than 20 minutes car will not start right back up turn the key all of the power comes on but nothing happens after waiting about an hour or more the car will start right back up I have taken the starter off had it checked it was good but I replaced the starter solenoids and it still did the same thing
Oct 15, 2013 at 8:37 AM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
So when the engine is hot and trying to start it the starter is inop and won't turn the engine over?
Oct 15, 2013 at 9:06 AM
STCHRIS96@AOL.COM
  • 28 POSTS
that is correct
Oct 16, 2013 at 2:02 PM
STCHRIS96@AOL.COM
  • 28 POSTS
All of the power comes on but after an hour wait it will start right up
Oct 16, 2013 at 2:04 PM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
Do you have a multi meter to do some testing?
Oct 16, 2013 at 2:11 PM
STCHRIS96@AOL.COM
  • 28 POSTS
no i don't have one
Oct 16, 2013 at 2:26 PM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
We need a multi meter to do some testing when the engine is hot and won't start.
Oct 16, 2013 at 6:03 PM
STCHRIS96@AOL.COM
  • 28 POSTS
give me the instructions on what do when i get the multi meter and what am i looking for and thank you very much
Oct 17, 2013 at 11:17 AM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
When its hot and won't start see if there is battery voltage at the white wire with a red stripe at the starter with the key in the start position?
Oct 17, 2013 at 7:54 PM
STCHRIS96@AOL.COM
  • 28 POSTS
And if it is not any voltage then what is the problem and if is voltage where do I go from there
Oct 18, 2013 at 7:02 AM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
If there is voltage looks like a bad starter if there isn't then we will have to look at other parts of the circuit.The starter is the most likely so I thought we would look at that first.
Oct 18, 2013 at 9:41 AM
STCHRIS96@AOL.COM
  • 28 POSTS
i replaced the starter silnoid so dose that mean the starter could still be bad
Oct 21, 2013 at 9:28 AM
SATURNTECH9
  • CERTIFIED EXPERT
  • 30,869 POSTS
Yes so what happened with the test I gave you to do?
Oct 21, 2013 at 3:19 PM
