Car turns over but wont start
1998 PLYMOUTH BREEZE
175,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
AAHALL1227
  • 7 POSTS
When cranking only getting spark on cylinder one. No spark on two, three or four. I replaced the coil and ignition switch but no chance. The 40 amp maxi fuse for the ignition system was blown when problem first occurred but replaced fuse and has not blown again. Car is getting proper fuel presume as well.
Jul 21, 2016 at 5:11 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Have you read the diagnostic fault codes? Do you have the single or dual cam engine?
Jul 21, 2016 at 5:40 PM
AAHALL1227
  • 7 POSTS
No I have not read the codes. It is the single cam I believe.
Jul 22, 2016 at 2:49 AM
RENEE L
  • CERTIFIED EXPERT
  • 1,260 POSTS
Hi AAHALL1227,
Here is a link to an informative article from this site with step by step instructions with pictures and a video on what to check for when your vehicle cranks, but will not start.
If you need any further help please come back to the site as we are always happy to help.
Thank you for visiting 2CarPros.
Kindest regards,
Renee
Admin
Jul 22, 2016 at 9:23 AM
AAHALL1227
  • 7 POSTS
Jul 22, 2016 at 11:36 AM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
The clue is in the diagnostic fault codes. Chrysler makes reading them yourself real easy. Cycle the ignition switch from "off" to "run" three times within five seconds without cranking the engine, leave it in "run", then watch the numbers show up in the odometer display.
If you get a code for " cam and crank sync", start by checking the timing belt to see if it has jumped two or more teeth. At one tooth off, the Engine Computer will turn on the Check Engine light and set that code. At two teeth off, the computer will shut the engine down to protect the valves. The classic symptom for that is spark at only one or two spark plugs.
Jul 23, 2016 at 12:57 AM
AAHALL1227
  • 7 POSTS
There are no fault codes showing at this time. I hooked the code scanner up and everything cleared with no readout. And the car does not have a display to show the codes. It's a low end model manual locks and windows and transmission.
Jul 23, 2016 at 10:13 AM
AAHALL1227
  • 7 POSTS
And I checked for spark at the coil not the plugs.
Jul 23, 2016 at 10:16 AM
AAHALL1227
  • 7 POSTS
The green wire with orange stripe on the coil connector only holds 10.7 volts while cranking.
Jul 23, 2016 at 10:20 AM
AAHALL1227
  • 7 POSTS
The timing belt is the problem thank you so much for your time and help.
Jul 23, 2016 at 2:17 PM
RENEE L
  • CERTIFIED EXPERT
  • 1,260 POSTS
So happy to hear your problem is solved. Thank you for visiting 2CarPros.com. We are here to help.
Kindest regards,
Renee
Admin
Jul 23, 2016 at 7:33 PM
CARADIODOC
  • CERTIFIED EXPERT
  • 34,308 POSTS
Happy you found it, but there's more to the story. You should have had a fault code for "cam and crank sync". You have a digital odometer display. That's where the code numbers show up.
The rest of the story is when the same code and symptoms show up, and the timing belt and marks are okay, it is common for the dowel pin to shear between the camshaft sprocket and the camshaft, then the sprocket rotates on the camshaft over time until the camshaft is late the equivalent of two teeth. All that's needed is to replace that pin. This only applies to the single-cam engine.
Jul 23, 2016 at 8:27 PM
