Car starts and idles roughly, press gas let go then stalls
141,000 MILES • 1.7L • 4 CYL • 2WD • AUTOMATIC
SAULM10
I was driving back home the other day and everything seemed fine. Out of nowhere on a stop my car began to shake then it just turned off and would not turn back on. I was able to make it crank when I turned the key but no luck on getting it started so I had it get towed home.
My brother and I worked on it, and we change the air temperature sensor but there was no luck. Today we cleaned the throttle body and the idle air control valve (did not replace them) and still no luck.
The car starts when it is cold and stays on idle with the idle rpm's moving up and down from 800-650 which makes the idle a bit rough. That was not happening before. So the car will be on when it is on idle, but once I press the gas pedal and then let my foot off the gas pedal the car engine will shake then turn off. I can turn the car back on and keep the gas pedal pressed (revving it) and the car will not turn off, but as soon as I let go of the gas then the car engine stalls. No check engine light is on. Anyone have an idea of what it could be or what it is?
GX model, MFI CNG SOHC.
Dec 30, 2017 at 2:19 PM
  • 55,682 POSTS
Two things come to mind for this problem the first is a vacuum leak which will cause the engine to stall and have a hard time. Here is a guide to help confirm the issue.
Next would be the crankshaft angle sensor but to be sure lets run the codes to see what comes up.
Please run this test and get back to us.
Cheers, Ken
Jan 4, 2018 at 3:44 AM
