Car turns off when reducing speed.
133,000 MILES
YANNICRISANTOS
  • 132 POSTS
When I'm driving my truck and braking during the stop light the car shuts off, this car is a manual transmission. When I'm slowing down and I'm on 3 gear and go to 2nd gear the car turns off. /.It's been doing this for a while but now the car turns off when I put the car on neutral and start braking the car turns off. I did replace all 4 oxygen sensors and ABS wheel speed sensor.
Sep 14, 2013 at 8:38 AM
  • 110,251 POSTS
Have you checked for vacuum leaks as well as the idle air control valve (IAC)? The IAC is responsible for maintaining the engine's idle speed.
Sep 14, 2013 at 10:42 AM
YANNICRISANTOS
  • 132 POSTS
I have not checked but I will but I replaced abs wheel speed sensor and the lights still turns on what could that be?
Sep 15, 2013 at 2:08 AM
  • 110,251 POSTS
If the ABS light is coming on, the best thing to do is have the computer scanned for trouble codes. That way you will know where the problem is coming from. Most parts stores will do it for free.
Sep 15, 2013 at 10:20 AM
YANNICRISANTOS
  • 132 POSTS
They scanned before and after but will be buy a computer scanner my selfbto check it 100% I will be back with updates
Sep 15, 2013 at 5:00 PM
  • 110,251 POSTS
I'll wait for your reply
Sep 16, 2013 at 11:26 AM
YANNICRISANTOS
  • 132 POSTS
If I donate will the donation go to you?
Sep 16, 2013 at 11:49 AM
  • 110,251 POSTS
No sir, it is used to keep the site going. But thank you for thinking of me.
Sep 16, 2013 at 11:51 AM
YANNICRISANTOS
  • 132 POSTS
Hello I finally fished the abs, checked that the cable was broken got it fix and it now good
Sep 30, 2013 at 10:59 AM
  • 110,251 POSTS
Great! I'm glad you got it fixed. Take care and let us know if you have questions in the future.
Oct 1, 2013 at 10:26 AM
