Car tugging
220,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
RAYMOND RIVERA
  • 5 POSTS
Is I press on the accelerator the car begins to tug as I'm driving 40 to 60 miles per hour tugging may increase when I take my foot off the accelerator it doesn't tug. I've tried several gas treatments and the treatments and clean out the jets. I don't know what's causing the problem or how to fix it.
Feb 27, 2020 at 8:20 PM
Good morning,
There are no additives that will help injectors. If it is an injector, a service needs to be done that will clean them. It requires special equipment to disable the fuel pump and injector a special cleaner directly into the injector for cleaning.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
How old are the spark plugs? This is the most common failure for this.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Also, how long has it been since you changed the transmission fluid and filter?
Feb 27, 2020 at 8:52 PM
RAYMOND RIVERA
  • 5 POSTS
I changed the spark plugs about 1 month ago and I had to change the transmission fluid three months ago, but I did not change the filter.
Feb 27, 2020 at 9:07 PM
Okay, I doubt the filter is causing this issue.
I would suggest having the injectors cleaned.
Feb 27, 2020 at 9:29 PM
RAYMOND RIVERA
  • 5 POSTS
Yes, it runs good besides the hesitation. hesitation starts at around 2 RPM's.
Feb 27, 2020 at 9:35 PM
I understand. It could still be an injector that is not spraying the correct pattern.
Feb 27, 2020 at 9:42 PM
RAYMOND RIVERA
  • 5 POSTS
Thank you for your help. one more question, can I clean the injectors myself?
Feb 27, 2020 at 9:45 PM
Not without special equipment to inject a cleaner directly into the fuel system.
Feb 27, 2020 at 9:47 PM
RAYMOND RIVERA
  • 5 POSTS
Feb 27, 2020 at 9:48 PM
You are welcome.
Always glad to help.
Feb 27, 2020 at 9:54 PM
