Car started, then shut off after about two seconds
90,000 MILES • 4.0L • V8 • 2WD • AUTOMATIC
IAN PROSSER
Now the starter motor does not crank but there is a whine when I turn the key to the start position, sounds like starter motor is turning. I have put the battery on charge and the motor is now turning a bit faster after about two hours charge but still not cranking the engine. The battery is about seven years old.
Sep 22, 2018 at 9:29 PM
  • 55,594 POSTS
Hi IAN,
It sounds like the battery is no good but to be sure here is a guide that will confirm the issue.
and if bad,
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Cheers, Ken
Sep 24, 2018 at 6:04 AM
IAN PROSSER
Hi Ken. Thanks for your reply. I have managed to get the car to start by jumping it so next move is to change the battery. Thanks for your help.
Ian
Sep 24, 2018 at 6:41 AM
  • 55,594 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Sep 25, 2018 at 2:25 AM
0242DKPW
While driving as normal the car runs fine, when going down a hill and nearing the bottom of the hill say coming to junction as the engine revs become less the engine will cut out as it will if stood at traffic lights for more than about thirty seconds or so the engine just stops running. I have taken the car to my local garage and they have checked the vacuum system as they thought that the likely cause, when the car is idling the engine becomes very lumpy then it will run smoothly again briefly then stop.
Sep 25, 2018 at 2:26 AM (Merged)
HMAC300
  • 48,601 POSTS
Try cleaning your throttle plate on both sides with choke cleaner and IAC hole if you have one. Then check fuel pressure.
MARCUSLAVET16
The car shut off on me the other day and it would crank back up but would not stay cranked. Now the car is cranking back up and still running. No warning lights are on nor service engine lights. Can you tell me what might be the problem or why it did that or should I be trying to have something check?
  • 110,248 POSTS
Check fuel pressure. Make sure it is within the manufacturer's specs.
