Sorry for the delay, The error code is P1186. And would like to share more
1) Takes 4-5 secs to start
2) when accelerating in 1st or 2nd gear, some times the RPM does not go beyond 3000 RPM - with check engine light, when I switch off the car and again start it accelerates beyond 3000 rpm
3) engine stops while driving, again starts
BUT all these above problems does not show when the fuel tank is full, and runs without any problem for approx 300 kms without the check engine light, then back with the above 3 problems.
Have visited some diagnostic centres and company service centre, no one is sure what has to be changed,
some of the recceomedations from the mechanic
1) weak high pressure fuel pump
2) accelerater paddle sensor
3) common rail
4) pressure sensor on common rail
Please Help
Monday, October 28th, 2013 AT 2:23 PM
