Engine shuts off while driving
260,000 MILES
LARRYHABERMAN22
When driving it will run fine and then kind of start to sputter and shut off. It won't restart unless I wait half an hour or so. Then starts and runs fine again. It used to shut off when idling for 10 to 15 minutes also but I put a new MAF sensor in. So now it idles fine.
Mar 5, 2022 at 3:54 PM
Good morning,
Does it run fine now with no issues?
If it does not, I would get a fuel pressure gauge and attach it to the engine and see if the pressure drops out. It could be a fuel pump. You can rent one at a parts store.
Ignition Switch "on", Fuel Pump Running 48-55 PSI.
https://www.2carpros.com/articles/engine-stalls
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Please let me know if you have any other questions.
Mar 5, 2022 at 8:59 PM
LARRYHABERMAN22
I put a new fuel pump in about a year ago.
Mar 5, 2022 at 10:56 PM
You still need to test it. It sounds like it is the issue.
Mar 6, 2022 at 2:58 AM
LARRYHABERMAN22
Alright I will try that. thank you
Mar 6, 2022 at 8:06 AM
You are welcome.
Always glad to help.
Let us know if you have any other questions.
Mar 6, 2022 at 5:43 PM
LARRYHABERMAN22
Had the codes read and it said 02 sensor bank1 sensor2. Would that cause it to stall?
Mar 14, 2022 at 8:25 AM
No, not at all. The rear O2 does nothing but monitor the catalytic converter.
Mar 14, 2022 at 10:23 AM
