Car stalling and back firing
140,000 MILES • 6 CYL • FWD • AUTOMATIC
KIM WILLMAN
Sometimes there is a problem starting and when it does sometimes it will not accelerate. It has back fired. Sometimes the engine also accelerates even when you do not push on the gas or if you push on the gas pedal it will not go.
Feb 17, 2017 at 8:50 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it. also, check for a vacuum leak, broken hose/one off etc., see link.
Feb 17, 2017 at 10:16 PM
