Hi, replaced the timing belt on the car listed above, and the car now stalls on idle and chokes off when hitting accelerator. Verified all timing marks are correctly aligned, replaced mass air flow sensor, cleaned EGR, tested compression and fuel pressure. Any thoughts? At a loss, thanks!
(Original codes: PO171, P0455, no longer present since initial diagnostic).
May 3, 2017 at 2:26 PM
