car seems to overheat when temperature gauge halfway
1998 OLDSMOBILE INTRIGUE
223,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
CASPAR5555
car runs fine when just started until the temperature gauge gets close to half way it starts choking and idling funny. Will chug and stutter a bit.. if I throw on a heater then it will bring the temp down and seemed to correct it but now that its getting warmer it takes last time until that gauge gets halfway,, I change the coolant temperature sensor thinking it might be that but that did not work so I'm not sure what's causing it
Apr 2, 2015 at 9:42 PM
HMAC300
  • CERTIFIED EXPERT
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge first then clean throttle plate and iac hole with choke cleaner
Apr 3, 2015 at 7:43 AM
