Car running rough and no power
115,000 MILES • 3.1L • 6 CYL • FWD • AUTOMATIC
BROWNING31
My car all at once started running rough and it lost power. Engine lights came on so i checked the codes and this is what i got; P0300 p0304 p0305 p0306 p0356. So this is what i have done so far;I check the power to each coil # 4, 5, 6, and i used a noid light and check all three coil plugs for a pulse signal. All checked out good.. I could not find any vacuum leaks. So i am not sure what else it could be unless its injectors or a fuel problem.
Aug 3, 2016 at 4:36 AM
HMAC300
  • 48,601 POSTS
that is a misfires but if that is problem I always direct people to a mechanic as that is cheapest option on these type of codes. You can check for vacuum leaks and intake cracking etc. and check fuel pressure with a gauge auto parts rent it. Other than that leave it to the professional due to could be injectors, sensors etc.
Aug 3, 2016 at 5:22 AM
