Vehicle listed above Lerado, is having the same issue was wondering if you every solved the issue or found a solution.
Nov 30, 2021 at 12:25 PM
✓Experienced Mechanic
I suspect you are referring to a post you read. However, I don't know which one. Could you let me know the specifics as to what's happening and if there are diagnostic trouble codes?
