Noise when going over a bump or turning steering wheel
90,000 MILES
STEVIESIN11
When I go over a bump or turn the steering wheel it sounds like something is stretching. That is the best way I can describe it. Any help would be greatly appreciated.
Aug 8, 2018 at 3:01 AM
  • 110,248 POSTS
Can you tell me if the noise is coming from the exterior front of the vehicle or if it is in the vehicle?
I need to say that this vehicle is not sold in North America, so I have no specific information. However, if the sound is coming from the exterior, chances are one or more of the bushings is bad. Bushings such as the sway bar bushings can creak when they dry out over the years. Additionally, control arm bushings can also make the noise. Ball joints which are dry and worn can do it too.
If the sound is inside, most likely it is in the steering column itself.
Here are a few links which discuss ball joint replacement as well as control arm bushings and sway bar bushings:
https://www.2carpros.com/articles/how-to-release-a-ball-joint
https://www.2carpros.com/articles/popping-noise
https://www.2carpros.com/articles/lower-control-arm-bushing-replacement
https://www.2carpros.com/articles/upper-control-arm-replacement
I hope this information is helpful. I added the links hoping you could see the components I am referring to and then inspect the ones on your vehicle. Let me know if you have questions.
Aug 8, 2018 at 12:42 PM
