car problems
2,115,678 MILES • 0.6L • 4 CYL • AUTOMATIC
JESS JAE VEE
when i am at a light the car does not pick up speed. I put my foot all of the way down on the gas and its like it wants to turn off. But after a few seconds the car picks up speed and it jerks back which causes the rpm's to go high like if its in another gear, but then it will go back to normal. i cannot figure out the problem can you please help? Thanks
Jul 2, 2016 at 9:36 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge, auto parts can scan for free and rent gauge.
Jul 2, 2016 at 10:02 AM
JESS JAE VEE
But the check engine light does not come on and the fuel pressure would cause the car to act like that?
Jul 2, 2016 at 10:03 AM
HMAC300
  • 48,601 POSTS
low fuel pressure will not necessarily set the check engine light and will cause engine problems like you are experiencing. fuel pressure should be 35-65psi key on only.
Jul 3, 2016 at 1:09 AM
