I recently blew a head gasket. I had the head skim and re-seated four valves. I also had some work done on the crank due to a clogged pick-up. Replaced all bearings to their new cup sizes, new oil pump and replaced all the rings as well. Once assembled and started the car started overheating, so I replaced the water pump thinking it might be the sole course of it but still it overheats. Took out the thermostat but still it overheats, had the thermostat checked out but it was all good since I replaced the thermostat housing just a couple of months ago. I flushed the cooling system and even replaced the radiator, but still it overheats to an extent that the water starts boiling in the water tank. Now I'm clueless what to do next. Please help
Mar 19, 2019 at 12:41 PM
