No crank no start issue
121,077 MILES • 1.2L • 6 CYL • 2WD • MANUAL
SASSSSS_PP
We started the car this morning and drove it down the road then turned it off. We have gone back to the car to restart it and engine will not not turn over. We have charged the battery, tried to bump start the car but nothing has worked. Any advice would be amazing. Thank you
May 22, 2021 at 7:22 PM
When you say it will not crank over, I assume you mean when you turn the key, the engine will not do anything? Meaning it will not turn over and try to start. Or do you mean that the engine will crank and turn over when turning the key but it will not actually start?
If the engine will not do anything when you turn the key then we need start with this guide:
Do you hear a click or anything when you try to start the engine?
we need to find out if the starter is getting voltage on both wires when turning the key. Unfortunately we don't have a manual for this vehicle to provide a wiring diagram but one wire will have 12 volts all the time and the other will have 12 volts only when you are cranking the engine.
Please run through this info and let me know if you have questions. Thanks
May 24, 2021 at 8:20 AM
