code p1610
200,000 MILES • 1.0L • 3 CYL • 2WD • MANUAL
MUSHUNJE
i removed the ignition after steering lock. now the car won't start with eeprom error code p1610.
Sep 20, 2019 at 10:17 PM
  • 110,248 POSTS
Welcome to 2CarPros.
If you replaced the switch and reused the old lock assembly, the vehicle is in lock mode. The vehicle computer doesn't recognize the key/switch assembly and believes it is being stolen.
I looked for nearly 20 minutes trying to find the directions for the relearn, but nothing is available. You will most likely need it reset by a locksmith or dealership. It will require specialized tooling.
I wish I had an easier answer, but what was done as the code provide indicates the immobilizer has prevented starting the vehicle.
Let me know if I can help in any way or if you have other questions.
Sep 21, 2019 at 1:36 PM
