Car not moving but comes on
2,000 MILES • 0.6L • 4 CYL • TURBO • AUTOMATIC
MAKINGS
Tried starting my car after the close of work and notice the the car comes on but does not move when the gear is selected. Secondly also notice that the starting of the car comes with a noise. What may be the problem
Oct 9, 2014 at 10:52 PM
  • 31,937 POSTS
Can be a number of things, you should go get a scan done to see if there are any fault codes set, does the engine start with throttle down? do you have any fault lights showing?
Oct 10, 2014 at 7:42 AM
MAKINGS
It's a hybrid camry and does not throttle down. Once you start the car there is a cracking sound, i live in Nigeria and most car mechanics are not used to the car, one told me it's the inverter. Can you please explain to me when an inverter is bad. Thanks
Oct 12, 2014 at 6:46 PM
  • 31,937 POSTS
If you press the throttle to the floor when you press the starter it should start in petrol engine mode, dose it do this?
Oct 23, 2014 at 9:36 PM
MAKINGS
It does not start even when throttled down.when you start it, it will come up with a cracking noise then goes off, even when started, it does not move and it goes silent and when throttled it does not move.
Oct 25, 2014 at 6:45 PM
  • 31,937 POSTS
Have you had a scan done for any set fault codes, not all codes will set a check light,
Nov 5, 2014 at 5:57 PM
