Hi.
Kindly assist me in finding the problem of my car.
First Problem:
When I start the engine it runs well but immediately the engine will change sound and run like it I wants to stop/switch off while the rave keeps going up and down on its own. Then suddenly the engine sound will go up and runs normally but the whole car will start to vibrate too much. We changed all the plugs and two ignitions coils which we found were not working. After that the vibration decreased but it is still there but not like before.
What could be the problem?
Second Problem:
The car looses power while cruising on the road. First it’s started by jerking as if it has run out of fuel. After that while I was driving at 80km/h, its suddenly lost power and came to a near stop. When I started the engine, its runs but still make the jerking movement. The mechanic suggested we change the fuel pump. We changed it, cleaned the tank and changed the fuel filter but still problem persists. May I also add that this problem started after the car has overheated due to pipe-heater-return leak but that was sorted out.
These problems are on and off. And there is no “CHECK ENGINE” light on the cluster.
What could be causing this?
I would greatly appreciate your help.
And where in the ISUZU KB 320 V6, 2000 MODEL, DOUBLE CAB, 4*4 is the coolant temperature sensor?
VEHICLE DETAILS:
Engine Number: 6VD1831735
VIN: ADMTFS25DAM912532
Thanks
Benny Nkosi
First Problem:
Second Problem:
VEHICLE DETAILS:
Thanks
Benny Nkosi
May 6, 2015 at 6:05 AM
