engine shut off and will not start
300,000 MILES • 1.8L • 4 CYL • 2WD • MANUAL
DWAIN ESTMENT
Hi all, i had the engine done over completely was driving it for a month then i had the cylinder head sent away for skimming, after putting it back it had a low ground reading on the engine. after putting a wire from the body to the engine the car started there after took it for a test drive around the block twice switched it off started again about five times it started. then when i wanted to go for another test drive the car just shut off and has not started again ever since. took it to the auto elect he says that the ECU was blown after having three chips on the ECU replaced the car still does the same. i am on the verge of cutting my losses and selling it. now i am turning to anybody out there for help please!
Feb 18, 2018 at 1:46 AM
  • 55,748 POSTS
These problems can be tough but we can get it fixed. To me it sounds like you have a crankshaft sensor or ignition switch that is failing. Can you test for spark when the engine will not start? Here is a guide to show you how:
Cheers, Ken
Feb 19, 2018 at 3:35 AM
DWAIN ESTMENT
Hi Ken, thanks for the information. the car was at the auto electrician and he told me the car has a voltage drop on the crank sensor when you turn the key he told me the ECU blew, but i have already had the ECU sorted out but the car still not starting.
Feb 19, 2018 at 5:16 AM
  • 55,748 POSTS
Okay, but does the ignition have spark?
Feb 20, 2018 at 3:56 AM
DWAIN ESTMENT
Hi, yes it does have spark and i already replaced the crank sensor.
Feb 20, 2018 at 3:58 AM
  • 55,748 POSTS
Does the engine sounds okay when it is turning over? Can you see if you have fuel pressure?
Please run this test and get back to us.
Cheers, Ken
Feb 20, 2018 at 4:10 AM
DWAIN ESTMENT
Yes it does. the only thing is there is spark up until the coil but from the coil to the engine there is nothing and the positive side on the battery gets hot when you swing the key.
Feb 20, 2018 at 4:12 AM
  • 55,748 POSTS
You have spark out of the coil but not out of the distributor? if so it sounds like the rotor and cap need to be replaced or does it have solid state?
Feb 20, 2018 at 8:57 AM
