Car jerks then stops rolling in reverse
108,000 MILES • 3.0L • 6 CYL • AWD • AUTOMATIC
SCOTTYJ247
My 07 ford fusion has began making a terrible breaking/grinding noise when I put it in reverse and rolled back after a few feet. It has now begun to do this in neutral when rolling backwards. The vehicle jerks a couple times then stops itself completely whether in reverse or neutral rolling backwards. When it did this the first time a few days ago, thick black fluid was found (not a large amount, just a line) where the vehicle was parked and smoke began rolling out from underneath the car. The vehicle goes in to gear just fine, both drive and reverse and has not problems while driving shifting gears.
Sep 15, 2014 at 3:27 AM
HMAC300
  • 48,601 POSTS
This sounds like you have a parking brake shoe that has fallen apart. Here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/parking-brake-shoe-replacement
Let us know what happens and please upload pictures or videos of the problem.
Cheers,
Sep 15, 2014 at 5:33 AM
SCOTTYJ247
Yep I found the shoe was metal to metal causing the noise. Thanks for your help you guys are great.
Sep 17, 2014 at 5:03 AM
