Car idles really low and stalls when I put it in reverse
120,000 MILES • 4.5L • V8 • FWD • MANUAL
CODY DUNNY DUNITHAN
My car ran fine, it wanted to stall once or twice a month when my foot was on the gas ran it real hard on the highway. Yesterday the alternator burnt up and I went and traded at a salvage yard for one from a Devill. I put it in and it ran good for an hour or so. I parked it went to go get in to drive started idles for a little put it in reverse the car stalls. If I am not on the gas not so much in drive looked down the dash said the battery is not charging. The connection was loose I tightened it and it ran good in reverse and drive still idles low, but the connection went loose again. I put a new nut on it it is staying right, but my car still stalls in reverse not so much drive.
Jun 1, 2016 at 2:44 AM
CODY DUNNY DUNITHAN
After I put the other alternator in, the cars idle was really low.
Jun 1, 2016 at 2:45 AM
HMAC300
  • 48,601 POSTS
try cleaning throttle plate on both sides and iac hole with choke cleaner. check for broken vacuum hoses/disconnected etc.
Jun 1, 2016 at 5:15 AM
