procedure needed to get a car running that has sat for ten years
75,000 MILES
B_WALTER60
Has been sitting for ten years. what would be the correct procedure to getting it running again? there was nothing wrong with it when I stopped driving it.
Apr 7, 2018 at 5:36 AM
Good evening.
Start with changing every fluid in the car. oil, transmission oil, differential oil, power steering fluid, brake fluid and coolant.
You should also drop the fuel tank, remove all fuel, flush the tank and change the fuel pump as well.
I would also remove the spark plugs and squirt some oil into the cylinders and hand crank the engine to get some lube on the walls and rings.
Lastly, replace the battery and all belts.
Apr 7, 2018 at 10:44 AM
CARADIODOC
  • 34,415 POSTS
Pop in a good battery and fire it up. Check for fuel leaking from the carburetor. If you see that, it may stop on its own, but expect to need to have it rebuilt. Use up the gas in the tank as quickly as possible, then fill it with fresh, new gas. If there was gasohol in it those ten years, mold feeds on the alcohol and will grow in the tank. If this shows up later as a stalling or very low-power problem, suspect the fuel strainer inside the tank has become plugged.
I have an 1980 Volare, (carburetor) and a 1993 Dynasty, (fuel injected) that regularly sit for more than five years between drives. I have never had a fuel-related problem, but that seems to vary around the country with different formulations.
Apr 7, 2018 at 10:49 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Three things usually happen after all that time, the gas in the tank is stale, the spark plugs are rusted and the battery is drained.
Apr 8, 2018 at 1:14 AM
CARADIODOC
  • 34,415 POSTS
I did not mean to intrude. We were typing at the same time.
I have never had a problem with old gas, but that is quite different than what I hear from people in other parts of the country. If the level is low in the tank, I would add fresh gas so the engine had something to burn, but stale gas will still burn once it has some good stuff to go with it, as long as it has not turned to varnish.
The two things I should have elaborated on with the carburetor are the gaskets and the needle and seat. Seals can dry out and shrink. They might seal again once they get wet. If the gas turned to varnish, the needle could be stuck and will not allow gas into the float bowl. Chances are the gas evaporated out of the float bowl and the needle opened up. Now corrosion or mold has formed on the seat and it will not seal. The bowl will overflow and the excessive gas will stall the engine. Watch out that a backfire does not start the engine on fire. If you get past the first few minutes, the detergents in the new gas should clean up the needle and seat.
I do have a problem with my Volare after it sits for many months. The gas evaporates out of the float bowl and goes into the charcoal canister. There was a service bulletin about adding a check valve to prevent the resulting long crank time. I have that valve but never bothered to install it. I have another problem that occurs when I purposely run it out of gas when checking the fuel mileage. The mechanical fuel pump will not draw a prime out of the tank when it is running at engine-cranking speed. I have to dribble some gas into the carburetor. It is a six-cylinder engine with really long intake runners so it is almost impossible to flood the engine. It will run as long as four or five seconds before that gas is used up. Sometimes I have to do that three times before gas is being pulled by the pump. Then the engine runs fine.
A lot of people worry too much about the oil, but that deteriorates from heat and blow-by. The oil itself has no more chance of going bad than if it had been sitting in the quart container on a shelf. What I do not know is once the oil has gone through a few heat cycles, how does that affect the life of the many additives in it?
I would go beyond suggesting the battery will be drained. The plates will be sulphated, and even if it is charged for days at a real slow rate, it is not coming back. There are people who say putting a really high pulsing voltage on it can restore it and boil the sulfation off. There are even special battery rejuvenators that claim to do that, but I have never seen or used one. Just plop in a new battery so you know there is one less thing to worry about.
If there was any one thing I would worry about most, it would be the transmission. Transmission fluid is going to slowly drain out of the clutch packs. That will leave the fiber plates and rubber lip seals exposed to air, and they'll dry out. When we rebuild a transmission, we always soak the new plates in transmission fluid before installing them. The seals get well-lubricated too. Over time those lip seal become hardened and brittle. They do not hardly flex much at all in operation, but when we pull one apart, those seals come out in chunks like little rocks. If you bend a piece, it cracks.
Dry fiber plates will become chewed up very quickly. To reduce the chance of damage, drive the car very gently at first with little load on the transmission. You might even consider shifting trough all the gears so you know every clutch pack has filled with fluid, then let it sit for a few hours so the fiber plates can soak in that fluid.
Apr 8, 2018 at 11:20 AM
