Car shut off with a burning smell
2007 NISSAN TEANA
75,800 MILES • 2.0L • V6 • 2WD • AUTOMATIC
VIJAYRAJ
My car got shut down with a burning smell. When I checked ,
the radiator pump got damaged and there is no coolant. I have planned to replace the radiator.
Should I replace the head gasket also?
Please advise.
Nov 15, 2020 at 9:08 AM
The head gasket is not something you want to do unless you know for sure that it is blown. Not only is it a lot of work but it could cause other issues if something is missed. So if it is not needed, I would not do it as a precaution.
Let's test the head gasket with this guide:
If the engine cannot warm up right now safely then we can do a compression test and if it passes, I would not do the head gasket and proceed with the repair to get it running and then do the head gasket test as shown above.
Here is a guide on a a compression test:
Let me know what questions you have. Thanks
Nov 15, 2020 at 9:16 AM
VIJAYRAJ
Thanks for the reply. Will try to proceed with the repair without doing anything on the head gasket and will do the above testing and let you know.
Nov 15, 2020 at 9:46 AM
Sounds great. We will wait to hear back. Thanks
Nov 16, 2020 at 11:09 AM
