Car shuts off while driving
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
JENBENJONES
Car starts with no issue and drives, but after a couple blocks it'll start to run rough and then the rpm will go up and down and then the car will start to shut down and then I can't restart it. After a couple hours I can start it and keep doing the same thing.
Dec 11, 2019 at 10:26 PM
  • 110,248 POSTS
It sounds like an issue with the crankshaft position sensor. When they start going bad, heat causes them to fail. As a result, you need to allow it to cool for it to restart.
Take a look through these links. The second link shows common symptoms. See if they mirror what you experience.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
_________________________________
Let me know which v6 you have and I can get directions specific to your vehicle.
Let me know if this helps
Dec 12, 2019 at 9:55 AM
