car dies in peak hour traffic only
198,000 MILES • 1.5L • 4 CYL • 4WD • MANUAL
ALBERT72
The car drives perfect except in peak hour stop start traffic, in appears to be starving of fuel till it won't restart at all even though having half a tank of fuel..it restarted this morning after sitting for 15 to 20 minutes other times I've top it up with $20 fuel from petrol can .happen 3 times now only in stop start peak hour traffic not long owned this car . Obviously why it was solded
Oct 14, 2014 at 3:20 PM
CARADIODOC
  • 34,414 POSTS
What you described is commonly caused by a plugged pickup screen inside the fuel tank. This applies to any car with the fuel pressure regulator on the fuel rail on the engine, and a return line to the tank. The typical symptom is the engine runs fine at highway speeds, but stalling occurs when the largest volume of fuel is being pumped, . . . which is during coasting.
Oct 14, 2014 at 4:55 PM
