car dies after running a while
18,000 MILES
JM7
The cars dies after running.10 minutes some time all day.and then won't start entell the next day or after compleatly cooling off. I have taken it to 3 defferant shops and thay can't find the problem. It has been hooked up toa diegnostc machine but to no.aveal can you help?
May 4, 2013 at 7:22 AM
when it does not start they need to check fuel pressure and spark to find out what system is failing
roy
May 4, 2013 at 7:40 AM
HONDATECH1983
  • 109 POSTS
Has the Main Fuel Relay been replaced? It sounds like relay symptoms. When the car doesn't start does the green key light on the dash blink?
Nov 20, 2013 at 10:36 AM
