CAR DIES AFTER I START IT
215,000 MILES • 1.9L • 4 CYL • FWD • MANUAL
DONNY9536
Ok I read another person has the same problem I do. he was advised to check plugs,wires, terminals .etc. Now I changed all that stuff out , E3 plugs,High dollar 8mm wires.No lights on in side the dash cause I just changed out the starter, . Once the motor starts if I don't keep my foot on the gas and ease out on the clutch it DIES, then I have to go full throttle and finale it starts, so when I go to take off, {forward or reverse} I have to give it a lot of throttle and some times I have to pump it, please help I love my little car.
Dec 10, 2014 at 10:22 AM
JOHNNYT73
  • 924 POSTS
Clean throttle body and idle air control valve port (valve may need replacing). Check fuel pressure with a gauge.
Dec 10, 2014 at 10:40 AM
DONNY9536
Thank you , Will do cleaning and check fuel pressure, will keep u informed TRhanks agaiun
Dec 10, 2014 at 11:37 AM
DONNY9536
Changed out coolant temp sensor and all is well now, runs like it used to.
Dec 12, 2014 at 5:02 AM
JOHNNYT73
  • 924 POSTS
Great! I was actually going to suggest that after you did those steps I provided were ok. I have done a few of those in my time lol. It's one of the main issues with these cars.
Dec 12, 2014 at 5:16 AM
SATURNTECH9
  • 30,868 POSTS
Also just to add to this one also check the inside of the coolant temp sensor connector if the terminals are blue or green instead of silver i would change the connector also.The sensors crack and leak coolant into the connectors corroding the terminals.Also i recommend only using stock copper plugs in those engines they run best for the longest time. Platinum etc i have seen have issues with carbon fouling. Those engines tend to burn oil i would use ngk ac delco or some bosch supers.
Dec 13, 2014 at 11:50 PM
