It starts but it idles high and then shuts off
2012 NISSAN SENTRA
97,000 MILES • 2WD • AUTOMATIC
TIFFTIFF
If rev engine it doesn’t shut off but if I let it idle it does.
May 28, 2021 at 6:16 AM
  • 110,244 POSTS
This could be the result of a few things. An engine vacuum leak can cause it as well as low fuel pressure. These are two things you can check without providing more information to me. However, if we need to start checking the idle air control circuit, I will need to know the engine size. It should be either a 2.0L or a 2.5L four-cylinder.
Here are two links I need you to review. The first one explains how to check for and repair an engine vacuum leak. The second one explains how to check fuel pressure.
Take care and feel free to ask away. LOL
May 28, 2021 at 11:54 AM
