When battery gauge fluctuates sometimes car will shut off
130,000 MILES • 3.6L • 6 CYL • AUTOMATIC
YOITSJUSTME
  • 34 POSTS
Battery gauge started fluctuating after the water pump was replaced. When it fluctuates it causes the car to shut off sometimes. When it does shut off it does not start back up immediately. Acts like it's not getting fuel then. Does finally restart. Seems to be worse when using the heater, radio etc.
Jan 17, 2020 at 3:17 PM
  • 110,248 POSTS
It sounds like a couple different things. Since the WP was replaced, that leads me to think there is a loose belt causing the alternator gauge to move around. Do me a favor. I need you to check the alternator output. It's really easy to do. All you need is a multi meter or volt meter. Here is a link that explains how it is done:
Here is a link explaining how to use a volt meter:
Next, when it refuses to restart, I need you to check if there is spark to the plugs. The crankshaft position sensor may have been damaged when the work was done. However, that shouldn't cause the gauge issue. Do this and let me know what you find.
One last thing. When the engine is off, check to see if the drive belt running the alternator is tight.
Let me know what you find.
Jan 17, 2020 at 3:47 PM
