Engine stalls
56,000 MILES • 2.0L • 2WD • MANUAL
KARL CUDMORE
I have a BMW 318i 59! Plate,. I was driving my car home one night and I was slowing down to change gear, put my clutch in and my engine would cut out however I could press start and it would come back to life, however this would happen even when I went to change from sixth gear to fifth etc., also it was juddering quite a bit when changing gear and also took a while to build up speed when accelerating. I have had a diagnostic done on the car no error codes were present. Could this be a clutch slipping causing this issue?
Nov 16, 2018 at 1:44 AM
  • 55,845 POSTS
It sounds like the throttle bore is dirty and the ECM loses correlation. I would disconnect the battery and then follow this giuse to see what happens.
Also has the engine been tuned lately? If not use OEM parts and follow this guide.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Cheers, Ken
Nov 17, 2018 at 2:30 AM
