Crankcase pressure is produced by the action of the pistons moving up and down the bore and combined with any blow-by past the piston rings, the pressure is vented via the PCV system, short of fixing the problem, you wont be able to control the excessive crank case pressure.
SPONSORED LINKS
Saturday, October 24th, 2015 AT 6:54 AM
