Possibility of installing cruise control
2013 TOYOTA COROLLA
25,000 MILES • 2WD • MANUAL
GHAZI.85
  • 5 POSTS
Can I add cruise control in my car listed above and use it?
Nov 13, 2018 at 4:29 AM
DANNY L
  • CAR REPAIR CONTRIBUTOR
  • 5,648 POSTS
Hello, I am Danny,
Sorry, unfortunately a cruise control system cannot be used on any vehicle with a manual transmission. Hope this helps and feel free to ask any questions. Thanks for using 2CarPros.
Danny-
Nov 13, 2018 at 4:40 AM
HARRY P
  • 2,292 POSTS
Danny I will have to differ with you here. I have seen cruise control on vehicles with manual transmissions. It does not do much more than holding the throttle and bumping it up and down, but it is usable. However, since the car is a manual, and the cruise system is not able to change gears like an auto would, it is nearly useless unless you are traveling at speed, on a long, straight stretch of road with virtually no elevation changes.
As for the original question, you would probably be looking at changing a computer or two, wiring in a switch, adding a cruise control servo, and other such things. Given the uselessness of having cruise on a manual transmission, I would not bother. It would probably be cheaper to buy another car with cruise and trade your current one in.
Nov 13, 2018 at 6:31 AM
GHAZI.85
  • 5 POSTS
Hey man1104, I could not understand what are you saying? Will cruise control work or not in manual Corolla 2012?
Nov 13, 2018 at 7:37 AM
HARRY P
  • 2,292 POSTS
It will, but because the cruise cannot shift gears up and down (in order to get more power as needed) it is pretty much useless. The cost:benefit ratio is terrible. Cost will be through the roof, and the benefit will be minimal.
Nov 13, 2018 at 9:56 AM
GHAZI.85
  • 5 POSTS
Okay, can I get bit transmission change and get automatic?
Nov 25, 2018 at 8:19 PM
HARRY P
  • 2,292 POSTS
I am sorry but since this is a new question please start a new thread here: https://www.2carpros.com/questions/new
Nov 26, 2018 at 3:11 AM
