Original remote start installation
120,544 MILES • 3.6L • 6 CYL • 2WD • AUTOMATIC
ABSY OMAR
I have the car listed above that comes with no remote start and i would like to know if i can install the original GM remote starter? Is this just plug and go system or need reprogramming BCM etc?
Omar from France
Regards
Jan 13, 2019 at 4:57 AM
  • 55,673 POSTS
Yes, you can install the GM remove start. it will need to be programmed in should cost about $130.00 at a shop. Please let us know what happens.
Jan 14, 2019 at 3:28 AM
ABSY OMAR
Could you explain more the process because actually i have the original remote key fob with no remote start. If i understand do you mean i need new remote start key fob plus a reprogramming BCM? I am confused, please let me know
Thank you for time you spent. Regards
Jan 17, 2019 at 6:50 AM
  • 55,673 POSTS
Sure, the remove start package includes a wiring harness and relay that will need to be installed and the BCM will need a program update to allow the BCM to trigger the relay to work the starter and allow the engine to run with the ignition switch off.
Jan 18, 2019 at 3:54 AM
