Can a bad BCM cause a miss?
250,000 MILES • 3.8L • V6 • RWD • AUTOMATIC
DW96
  • 8 POSTS
While going down the road in my 99 Firebird I will go from a lower RPM range to a higher one and the engine misses....I've replaced plugs and wires in the last month...I put iridium plugs in it...I have upgraded the coils to a higher heat range...I was wondering if the BCM could be getting flaky and occasionally activating the security system for a split second and then turn it off
Feb 11, 2016 at 9:24 AM
JOHNNYT73
  • 924 POSTS
hmm...check around for vacuum leaks and do a fuel pressure test.
Feb 11, 2016 at 9:27 AM
DW96
  • 8 POSTS
Sadly I've just replaced the fuel pump in it too
Feb 11, 2016 at 9:29 AM
JOHNNYT73
  • 924 POSTS
try putting the old coils back on and see if that changes anything.
Feb 11, 2016 at 9:30 AM
